This machine is making line type streaks on the front and back of the copies my thoughts are the transfer belt and roller any on have any other thoughts if you run mm 089 the lines and streaks are just black but it's on every copy front and back single side coping
TASKALFA 2551 CI
Re: TASKALFA 2551 CI
I really cant believe some of the thing you techs suggest. i cant believe your techs you guys would never make it at my place. Very rarely do i see anything you guys suggest thats even close to a fix. Are you techs trained or just wing it. All of these problem are common everyday problems we see here in atlanta. If this machine when you pull a status page if it's not showing up on there it's the sensor board. If it was generic toner the machine would ask you to ok it before continuing. to make you aware it generic toner in this model anyways
If you post pics of the problem, you may get a faster response. The transfer belt as you mentioned may be the most likely issue. vacuum the toner waste exit port on the transfer belt and see or just replace the belt under warranty.THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burke -
mr. Simonsays, you posted the above in another thread. Now you are asking for what !. No wonder the three red cards. Can't you control your tounge. Make a cup of tea and drink it while your write, you need to relax a bitl.
If you post pics of the problem, you may get a faster response. The transfer belt as you mentioned may be the most likely issue. Vacuum the toner waste exit port on the transfer belt and see or just replace the belt under warranty.Comment
listen ive been here a very long time and what i'm saying is you guys aren't applying yourselves i've been doing this for over 30 years and i haven't found one of these machine that can beat me take it how ever you want. Sorry if you don't like the truth. my dealership is the biggest around why because we fix machines with no excuses and i dont listen to excusesComment
Mr., you are not a team player. When you are on the team, you encourage and learn from mistakes and try to do better. This is what the guys here attempt to do. Helping one another with suggestions even though some may be the incorrect answer. Have not seen a perfect tech here and i don't think i ever will.
You want perfect answers for all your questions every time you post, then you have ill thoughts.
I think you need some attention, someone to argue with, and someone to put up with your crap.THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burkeComment
funny thing is the machines already fixed not from any help from you and nothing suggested here was even close smart ass like i said before dito!!! and we are the bestComment
I think you need some attention, someone to argue with, and someone to put up with your crap.Comment
It's time to analyze this thread...
(Seems like a reasonable request, that's what this site is here for)
(please excuse the double negative, it was for comedic effect.)
(The customer called in and said, please send a different tech next time, the last guy was here 5 times and it's still broke)
Ask any of my guys if im a team player you wish you had a owner as generous as me we have a real team i dont even have to ask i have many guys that will go any distance to do the job. So keep working for 32,500 see how good you live. I know ive been there next time your in atlanta look us up and see for yourself. your more than welcomeLast edited by Ctl-Alt-Del; 09-09-2016, 07:27 AM.Comment
it's time to analyze this thread...
I can't fix it, i need help
(seems like a reasonable request, that's what this site is here for)
but i can fix everything, i've never not been able to fix everything, i can't be beat, even my meat can't be beat.
and your the first guy to go when things get tight
wow, machine is already fixed, i didn't fix it but i'm still the best. Btw, i'm not going to tell you how it was fixed because the guy that actually fixed it won't answer the phone when i call.
(the customer called in and said, please send a different tech next time, the last guy was here 5 times and it's still broke)
btw, i work at a big dealer and even though i have no use for reasonable punctuation and grammar, i make a lot more money than any of you so i'm better.Comment
very true maybe if you applied your craft you could be as good as me or reach into your pocket and pull out 5000.00 at any given time. Any time you would like to compare your skills to mine im up for it. I wouldn't want to embarrass you. One thing you can beat me at is your trolling skills i love you guys who hide behind your computer and talk shit
HP 4345 MANUAL FEED TRAYI dont work on these much so i could use some help on this using the manual feed tray it pulls the paper just before the charge roller then stops dead but the rest of the trays feed fine the feed tire looks ok too
Mr. The above is your request for help. If you are that good as you claim in the above you won't be posting. I think you are looking for sympathy and to pull down others with you. The guys here are not that naive, and is not baited that easily. Tell me, why do you have all those red cards, you are in the penalty box and it's a sign of your demeanor. So smarten up and have decent conversations or no one will actually respond to you anymore, at least not me.
Post something worthwhile to redeem yourself and start getting back on the greed cards. Don't keep that yoke upon your neck, it just weights you down.THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burkeComment
hp 4345 manual feed tray
i dont work on these much so i could use some help on this using the manual feed tray it pulls the paper just before the charge roller then stops dead but the rest of the trays feed fine the feed tire looks ok too
mr. The above is your request for help. If you are that good as you claim in the above you won't be posting. I think you are looking for sympathy and to pull down others with you. The guys here are not that naive, and is not baited that easily. Tell me, why do you have all those red cards, you are in the penalty box and it's a sign of your demeanor. So smarten up and have decent conversations or no one will actually respond to you anymore, at least not me.
Post something worthwhile to redeem yourself and start getting back on the greed cards. Don't keep that yoke upon your neck, it just weights you down.Comment
