taskalpha 2550ci pcb
  • johnny32
    • Oct 2007
    • 102
    wondering if anyone would know where i could get my hand s on the following board 2nd hand as to expensive new.
    Part Code: 92MV94230
    Description: MAIN PWB ASSY EU
    I am based in ireland
  • Tonerkiller
    • Oct 2012
    • 668
    Re: taskalpha 2550ci pcb
    What kind of a problem are you having with the machine? I always say that it is never the main board.
    • subaro
      • Oct 2010
      • 1274
      You know i wanted to make the exact remarks as above, but took the path of caution. so i second the above. Very, very rare i replace a mainboard.
      • johnny32
        • Oct 2007
        • 102
        Dead control panel. Tried firmware upgrades from usb and also the cf card with no joy. When power is turned on green light on control panel flashes and nothing else. Also fan connected to main pwb does not cycle
        • johnny32
          • Oct 2007
          • 102
          johnny32's Avatar Join Date
          Oct 2007
          Location
          cork
          Posts
          76
          Post Thanks / Like
          Rep Power
          19
          Quote Originally Posted by Tonerkiller View Post
          • copier parts n.ireland
            • Nov 2016
            • 41
            Gabbey Business Machines N.ireland in belfast has 2 of these scrappped for parts,well worth a phone call.02890 451517
            • The Hastings
              • Apr 2016
              • 21
              Try HyTec
              Factory Authorized Circuit Board Repair by Hytec Dealer Services, Inc.
                • Nov 2016
                • 41
                thank you,i have a faulty main board as well only for the utax cd 1435 model,screen is not lighting up,was going to scrap but now might be worth getting circuit
                fault traced and repaired if economical
                • Printmend
                  • Aug 2012
                  • 67
                  Hi Johnny,
                  I have the same problem.. Did you get this resolved? if so was it the main board or the display or both???
                  I am based in Sligo, any help appreciated.
