paper misfeed in left door on kyocera km 2550
  • Sema
    • Apr 2016
    • 36
    hello friends
    I have a kyocera km 2550, it shows "paper misfeed in the left door remove jam 61" yet there is no paper that is stuck.
    When i open the left door, the message clears and machine works ok, then after like 10 or 20 copies, it displays the error message again and so the error is on and off.
    The feed rollers still good and i inspected all the sensors, are all ok and non of them is stuck. Idont know the cause.
    what could be the cause? I need some help
  • JR2ALTA
    • Feb 2010
    • 2031
    Re: paper misfeed in left door on kyocera km 2550
    The spring for the registration actuator falls off causing the flag to hang up and not return. It's at the rear side of the machine, hopefully you can find it.
    • qtech
      • Jul 2009
      • 41
      Feed clutches do not last forever on this series; have replaced many over the years.
