Kyocera fsc8520 changed toner then sudden problem
  • Service@PRT
    • Oct 2016
    • 181
    With newly installed cyan toner i encountered a problem where a copy or printing colored it has a shadowed. i clean drum, transfer belt, dv. still got the same problem.
    this is the original
    and this is the outcome
    thank you very much.
    hope for your input.
    Every day of life is a learning process...
    Just make sure you are open in all aspects of comments.
  • copiman
    • Sep 2011
    • 861
    Re: Kyocera fsc8520 changed toner then sudden problem
    Your attachments are invalid due to file type therefor we cannot see them. Valid file extensions are Valid file extensions: avi bmp doc gif jpe jpeg jpg pdf png psd txt zip.
    May want to include more information like are you using compatibles or OEM toners. Meter count. Last PM meter. Etc...
    • Service@PRT
      • Oct 2016
      • 181
      thanks for the answer. already solved the problem with this one... just changed the tb. it reach its peak already.
      so its closed.
