FS-3640 J0020
  • copiman
    • Sep 2011
    • 861
    FS-3640 J0020
    This seems to be intermittent. Thought I would see if anyone knows if jam code 0020 (does not reach eject sensor) is a known issue. Paper does not get to drum but is in reg roller. Firmware current. Nothing in bulletins.
  • Alexkyocera
    • Jul 2015
    • 82
    Re: FS-3640 J0020
    Originally posted by copiman
    this seems to be intermittent. Thought i would see if anyone knows if jam code 0020 (does not reach eject sensor) is a known issue. Paper does not get to drum but is in reg roller. Firmware current. Nothing in bulletins.
    was a fix found???? Having the same issue
    • Kyo fan
      • Dec 2013
      • 368
      Re: FS-3640 J0020
      What's the total counter on it? Usually above 500k registration actuator is shortened by paper and has to be replaced in order to trigger the sensor below.
      • Alexkyocera
        • Jul 2015
        • 82
        Re: FS-3640 J0020
        The machine surpass 350k was at the customer for over 4 years. Going to send you event log
