Kyocera FS-C5350 colour alignment out
  • jonbonse
    • Jun 2009
    • 737
    Hi all
    i have an issue with an FS-C5350 where both magenta and cyan are out of alignment by around 10mm horizontally.
    I have reseated Devs drums and ITB, calibrated etc no difference...
    As the machine has two LSU's, one for both black and yellow and one for magenta and cyan, I am lead to suspect the magenta/cyan LSU...
    Any ideas?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Kyocera FS-C5350 colour alignment out
    Did you try with color registration correction?
    • jonbonse
      • Jun 2009
      • 737
      Yes I have wrong colour correction and colour calibration numerous times with the same result.
      I have just been in today with a new laser unit, cyan and magenta developer units and main PWB none of which have made a difference.
      • jonbonse
        • Jun 2009
        • 737
        I just found out there is a special firmware for this problem that resets the alignment .......
