Bizhub 423,552, C25 HDD wipe and size
  • Geo
    • 662
    Hi All
    I need to completely wipe the HDD on a Biz Hub 423,552 and C25. ( a little hand holding please, not a Biz hub junkie)
    1) Can I do a complete wipe from the op panel, if so how?
    2) What size HDD do they take and can off the self ones be used (thinking of doing a swap)
    Thanks for the help.
    Geo
  • allan
    RTFM!!
    • 5462
    Re: Bizhub 423,552, C25 HDD wipe and size
    Firts of all what is the purpose?
    To reuse or for security?
    Whatever
    • Geo
      • 662
      Hi allan
      They are going back to the leasing company and the customer wants the drives "wiped" ..So I guess for security.
      Thanks...
      • allan
        RTFM!!
        • 5462
        One way is to do a physical format. But with some effort data can be recovered.
        The recommended way is to overwrite all data.
        Under utility->administrator->security settings ->HDD/SSD settings -> overwrite ALL data.
        I believe a user manual would cover this.
        Whatever
        • allan
          RTFM!!
          • 5462
          The C25 does not have the overwrite function. But can be formatted from from -> sys default menu -> HDD format all.
          Or remove the drives and use a computer to overwrite them.
          Whatever
          • nathicana
            • Aug 2008
            • 333
            Last time I ran overwrite all HDD data I ended up with a d012 code.
            Does anyone know how to run overwrite and leave the machine running?
