Kyocera FS1300d wont print last part of LGL document
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    Printer driver is updated, I have chosen different configurations for the machine to print all text in the document,
    (tried different documents), however last 4 inches are washed-out to blank print, the printed area is larger than LTR-R but smaller than LGL
    I have tried the personalized settings as well with the same results.
    any idea is welcomed.
    My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
  • copiman
    • Sep 2011
    • 861
    Re: Kyocera FS1300d wont print last part of LGL document
    Not 100% sure about this issue but have you confirmed that the printer recognizes that legal paper is in it? In copiers I have seen that the paper size was different than what is in copier.
    • rapidocument
      Multibrands Tech
      • Jul 2012
      • 381
      I am seeing that this little machine came with win97 drivers and maybe is a conflict with win7 and win10 enviroments.
      Any way I have managed to make it work passing the LGL thru the bypass.
      all ok so far.
      thankyou guys
      • qbert69
        • Mar 2013
        • 1152
        Originally posted by rapidocument
        I am seeing that this little machine came with win97 drivers and maybe is a conflict with win7 and win10 environments.
        all ok so far.
        thank you guys
        If you are using Windows 10, you *should* be able to do print driver isolation!
        REACH FOR THE STARS!!!
        Konica Minolta Planetariums!
