Kyocera Ecosys p6035cdn drum yellow problem
  • docdot69
    • May 2016
    • 53
    Hi there,
    I was searching for any possibility of replacing any of the drum unit in this machine because the yellow drum seems to be damaged and seqently prints yellow short lines every turn on every page. But i found nothing about spare drum units. Is the drum unit replecable in this machine? or just have to buy a new machine?
  • T_foot2
    • Nov 2011
    • 22
    Re: Kyocera Ecosys p6035cdn drum yellow problem
    each color had its own drum unit.
    • mita
      • Sep 2010
      • 87
      Yes they use DK-5160
      • daveh12
        • Jul 2012
        • 157
        Think on those machines drums are interchangeable, no harm in swapping the yellow with one others to see if the problem follows. At least you will know if in fact a drum is what you need.
        • mita
          • Sep 2010
          • 87
          They are interchangeable (all the same part number.) and as said above I would swap one around with another to see if the problem follows
          • docdot69
            • May 2016
            • 53
            but how can i get to the drum units? seems like the only way to get to the drums is dissassembly whole printer. anyone got service manual to this printer?
            • docdot69
              • May 2016
              • 53
              so after replacing with other one for example cyan, if the drum is damaged, there should be cyan lines, scratches on the prints as i suppose...
              • wragsdale
                • Jul 2014
                • 188
                Drum removal only requires removing the toner cartridges, closing toner inlet shutter, removing 1 screw and cover, lifting a lever release, and then removing the itb. You will then be able to lift out the drum(s). There may be an extra screw in there that I'm forgetting about, but the whole process takes less than 3 minutes.
                • docdot69
                  • May 2016
                  • 53
                  that big black plate under toner cartridges? with one screw and grey lever on left side? have you got any video link or screenshot?
                  • wragsdale
                    • Jul 2014
                    • 188
                    That's the ITB. Pull the yellow shutter on the right towards you and remove one screw on the same side. On the left side, there should be a cover with a screw. Remove the screw and cover and then lift up on the black lever. You can then remove the ITB by lifting on the handle all the way up and then pulling straight out.
                    • Hilltoner
                      Hi I have an issue with the black has scratch on drum have taken all toners and itb out but how do the drums actually come out do not want to damage others is there a lever or something that holds the drums in place.
                      Regards Kym from Australia.
                      • D_Ritter
                        • May 2010
                        • 16
                        You can simply remove it, no levers or screws.
                        • darry1322
                          • Oct 2010
                          • 817
                          There is a square grey cover in the corner of the belt cavity that you remove to take the transfer belt out.
                          Underneath that cover is a grey lever that you move to the up position to retract the drum drive couplers.
                          • Hilltoner
                            Thanks to all not as easy as it sounded but fixed now.
