kyocera FS 6530 new machine
  • 1stcavvet
    • Apr 2015
    • 231
    [Misc] kyocera FS 6530 new machine
    I installed this machine last week and didn't notice it at the time. The customer says that the ADF seems really slow, I'm going out to see , Does anyone have any ideas on settings to look for, something that would be the reason for it to seem slow. DPI settings , adf looking in color instead of B/W. any ideas would help Thanks
  • The_Murph
    • 96
    Re: kyocera FS 6530 new machine
    I would pull the specs for the FS-6530 and compare the spec speed to the actual speed. It could be that the customer is just used to a faster scanning adf. I wouldn't assume that there's a problem without getting eyes on it first. That's not exactly the Corvette of doc feeders...
    If you phrase your inquiry properly, you will get the answers you seek...
    Good Luck ... You'll need it! HAHAHA!
    ~Big Dan~
    • 1stcavvet
      • Apr 2015
      • 231
      I figured I would look @ dpi settings and check the send settings make sure it's looking at TEXT b/w if the dpi is high it would slow down to be read better. I think, that's why I was asking. customer sounded a little sad ----- I said I would check some things Thanks
