Kyocera-M2535dn "Printing multiple copies is not allowed"
  • bigdcopy
    • Dec 2010
    • 70
    [Error Code] Kyocera-M2535dn "Printing multiple copies is not allowed"
    I have a customer that is attempting to print multiple duplex sets (10 sets) of a 20 page pdf file on win 10 computer it starts to print then comes up with this message:
    This machine has 512 MB standard memory and 32 MB ram disk (which is enabled)
    Side note this customer also has an 1135mfp with 256MB standard memory and 0B ram and it works fine
    customer is using WIN10
    I have gone into the driver default settings and
    Unchecked collate
    Set the driver to PCL5
    Disabled advanced printing features
    None of this helped
  • lebo
    • Aug 2012
    • 88
    Re: Kyocera-M2535dn "Printing multiple copies is not allowed"
    Dissable ram disk in printer driver as well as on the panel of machine Button System menu/counter > Common settings > Ram disk mode (restart machnie is needed for apply change) and try printing if something will change.
    • Kyo fan
      • Dec 2013
      • 368
      You have mismatch on the ramdisk settings. It has to be set to on or off on both sides (the machine itself and the driver), otherwise you will get that message. Also, restart the machine after every ramdisk change.
      • Blackspear
        • Mar 2021
        • 2
        Originally posted by Kyo fan
        You have mismatch on the ramdisk settings. It has to be set to on or off on both sides (the machine itself and the driver).
        Where do I find this for the Driver?
        RAM Disk is set to ON and 32Mb within the machine.
        Cheers
        • Blackspear
          • Mar 2021
          • 2
          Resolved thanks to Kyocera Customer Support:
          1. Uninstalled current driver
          2. Reinstalled the KX Driver: https://downloads.kyoceradocumentsol.../KX_Driver.zip
