Taskalfa 5002i service mode
  • Konicatech
    • Feb 2016
    • 133
    Hi guys,
    can anyone tell me how to get into service mode on this machine? It's usually konicas I work on but need to put a fax on one of these.
    thanks
  • Konicatech
    • Feb 2016
    • 133
    Re: Taskalfa 5002i service mode
    Manual states to access u600 mode to initialise the fax. How do I do this?
    thanks
    • eholyst
      • Jun 2013
      • 20
      Usually you can just install the fax. It does not require a maintenance mode to work correctly. u600 usually pertains to resetting the fax unit to factory defaults if something was not working correctly. However with that being said to access that on the keypad type in 10871087 and then 600 that should get you what you need.
