I currently have 4 machines with a little issue. hoping to get some out of the box suggestions.
1. TASKalfa 4002i. MAchine is displaying a JAM0000 error code, everywhere checked, no paper. Conveying unit replaced nothing. U031 ran to check sensor. DU2 sensor is ON, cant get it off. I disconnected the clutch and reconnect be nothing. Engine, Main broad replaced. Any ideas?
2. TASKalfa 5550ci. JAM 0000 however when machine turns on cassette one automatically starts to lift, the motor keep turning with/without cassette tray. Sensors replaced, engine interchanged,,,,any ideas.
3. FS-3640- A firmware update was being done remotely using Kyocera fleet management tool, but the power went and the machine is stuck on welcome screen. Firmware tried, nothing, panel MMI firmware done nothing, emergency firmware nothing. The USB port works. the NIC works, when plugged in via network the light flashes. Any ideas
4. TASKalfa 2551ci displaying a C9540 error code. after moving around some parts and board, however all the parts are back in their original machine but code still comes on. any ideas?
