TASKalfa 2551ci. Error code C9540, Any ideas other than the obvious
  • Alexkyocera
    • Jul 2015
    • 82
    Two machine was present parts were switched around. one machie working okay now but the other had a 6600 error code but now displays C9540.
  • Luther
    • May 2006
    • 682
    Re: TASKalfa 2551ci. Error code C9540, Any ideas other than the obvious
    Check DP to machine connections, particularly the add-on board that is installed with the high end feeder, make sure that it is seated to the main board or you or one of your end users has attempted to make copies of currency, stocks, or bonds. Only the manufacturer, Kyocera, can help you recover function of this machine
    • Alexkyocera
      • Jul 2015
      • 82
      this code occurs after swapping out parts from one 2551ci to another
      • JR2ALTA
        • Feb 2010
        • 2030
        Did you swap a board? you can get a counterfeit code by extremely bad luck. here's proof Error c9540 Taskalfa 500ci? - Topic
        good thing is it's busy work ahead of you. not like you sliced a wire out of a 6 foot long harness...
        • Alexkyocera
          • Jul 2015
          • 82
          im going to swap the scanner PCB and see what happens, after I will have to try and contact kyocera
