ECOSYS M3540idn not pulling single sheets from the bypass
  • n25an
    • Jul 2008
    • 1030
    [Jamming] ECOSYS M3540idn not pulling single sheets from the bypass
    i got a m3540idn that works great even from the bypass save every once in a while it will not be able to detect single sheets...
    the tray will snap up... the paperfeed roller will try to pull but will not be able to get traction. the tray snaps up and down a couple of times then reports a jam... The roller looks new... I am replacing the bypass paperfeed kit... I am checking if there is anything else I should take a look at... as always this is from the desktop family of kyocera mfps... so anyone with experience on these... feel free to chime in...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  • aktasson
    • Feb 2017
    • 201
    Re: ECOSYS M3540idn not pulling single sheets from the bypass
    First of all i would say - firmware update first. Actual version is 06.07.0010. Do you have the e-log file on usb stick? On the e-log printout have a look to the jam errors and codes.
    • n25an
      • Jul 2008
      • 1030
      nope but I can get the firmware... I also have the paperfeed kit for the bypass on order... along with the cork strip that sits on the tray...
      • Kyo fan
        • Dec 2013
        • 368
        You will need to replace entire drive feed assy.
        • n25an
          • Jul 2008
          • 1030
          thankfully never got that far... I replaced the bypass feed rollers and separation pad... while doing that I realized something... the springs could be weak... so I raised the base for the springs that supported the flap that goes up and down... spring on left and right... by doing a macgyverism... I used a piece of paper to elevate the springs a bit... after that it worked like a charm... the roller out was a bastard... took out the whole front cover... never want to do that again...
