Kyocera - Looking for Test chart
  • Chicko
    • Sep 2015
    • 36
    Hello
    I Have a Kyocera FS1128 and I accidently put the scanner off setting by doing U411.
    I'm looking for test chart / adjustment chart in order to set the machine back to normal scanning.
    Adjustment chart numbers
    302FZ56990
    and
    303LJ57010
    If someone can upload a high res pdf I will really appreciate it.
    Thanks alot
  • wragsdale
    • Jul 2014
    • 188
    Re: Kyocera - Looking for Test chart
    I don't think you want to do that. You want to calibrate your scanner from a print of a scan? And this doesn't sound like a bad idea?
    • Santander
      • May 2009
      • 768
      Originally posted by Chicko
      Hello
      302FZ56990
      and
      303LJ57010
      Thanks alot
      How about doing a U021 to get back to the default settings? You may have to re-enter some information, but you would have the scanner settings back to where you want.
      • Chicko
        • Sep 2015
        • 36
        Really? I wasn't sure about trying U021 as I didn't want to cause any other faults. I normally work with Ricoh machines which are different from these.
        So you say that this SP Mode will reset the machine back to defaults?
        • Chicko
          • Sep 2015
          • 36
          Yeah I know its not the best idea but if I can get it as close as possible that will be fine
