Cleared code, replaced fuser, engine pwb and fuser pwb, upgraded firmware. What else should i reset or replace, thanks for replys
kYO-6500I FUSER ERROR C6030
Re: kYO-6500I FUSER ERROR C6030
I would check that connector that the fuser plugs into.Last edited by Tonerkiller; 06-20-2017, 09:14 PM.Comment
Hello
There has been a change for this code since Firm V3.06
(Corrective measures for the C6030 error (Broken fuser thermistor 1 wire).
The service call error condition below is eliminated that depends on the environment and printing condition.
-The TH2 as thermistor 2 detects 30oC or less while the TH1 as the thermistor 1 detects 70oC or more during warm-up (eliminated).)
Can be tested with a new Firm.
best regard
Do not lament,do not mock,do not hate,but understand.
