FS-6525 finisher
  • nathicana
    • Aug 2008
    • 335
    FS-6525 finisher
    I'm having trouble installing a DF-470 into an FS-6525. There doesn't appear to be an electrical connector for the attachment kit AK-740. I must be missing something.
    The instructions show prying off a cover to expose the socket then sliding in the AK-740. My machine just has a flat wall where the removable cover is supposed to be.
    Has anybody installed a finisher on an FS-6525 recently?
  • Santander
    • May 2009
    • 768
    Re: FS-6525 finisher
    Your picture shows where the bridge unit slides in, the bridge unit is powered by the finisher's power source unit, When you install the bridge unit it does not have a connector in the back wall as you suppose. Slide in the bridge unit, install the power source on the left side of the unit, which connects in the back, install the finisher on the frame and install the exit tray per instructions, you are done. By the way, an AK-740 is not used on a FS-6525, it is for a totally different series of machines! What finisher are you trying to install??? The only finisher for a FS-6525 is a DF-470.
    • nathicana
      • Aug 2008
      • 335
      Thank you. I have the wrong attachment kit.
