TASKalfa 4551ci color background...???
  • cmpelser
    • Jan 2008
    • 173
    hi,
    strange one... color background on all paper weights except Heavy 1,2,3,4 settings... (on thick paper setting prints are perfect!)
    Re: TASKalfa 4551ci color background...???
    Originally posted by cmpelser
    hi,
    what have you done to try and correct it?
    what are the life % of the consumables?
    how heavy is the back grounding?
    a little more info would be great if you want us to help you.
    • Tonerkiller
      • Oct 2012
      • 668
      What color? It is either the charge or developer unit of that color.
      • cmpelser
        • Jan 2008
        • 173
        EVERYTHING has been changed!!! trust me... all the insides and all the boards!
        all 3 colors (CMY) are about the same intensity of background...
        all memory cleared back to factory defaults etc...
        like I said... its only when I put it on thick paper setting that is prints properly...
        • Santander
          • May 2009
          • 768
          You do not state what the color of the background is, it can not be all four colors as that would be black. Knowing what color the background is would help. Had one a few months ago that always produced a yellow background, changed everything only to discover that toner dusting was shorting out the charge grid creating the yellow background.
          • n25an
            • Jul 2008
            • 1030
            post samples
            Sad To Say I Don't Have a Life
            I do this stuff on the weekends too
