M2035 Blank Copies through DP and on Glass
  • buzz
    • Aug 2013
    • 288
    Blank pages are printing when copying on the glass and from Document Processor. Internal printing is fine (status pages, maintenance reports...).
    We brought this machine in for varying lead edge issues and were adjusting lead edge timing and all of a sudden the copies are blank .
    The exposure lamp turns on.
    Current Combined Firmware is uploaded.
    USB thumb drive file printing is fine.
    Scanning to USB thumb drive shows all black document.
  • Santander
    • May 2009
    • 768
    Re: M2035 Blank Copies through DP and on Glass
    If internal reports are printing fine you have gotten the scanner values way out of wack. Have you done a sim 21 to restore the unit to the default values. That is where I would start as you seen to have gotten the scan values so out of wack the unit cannot see the beginning of the scan page.
    • buzz
      • Aug 2013
      • 288
      Thanks for the tip. I'll definetely restore the values. I also found auto adjustments on U411 but waiting for the test charts to come in first. Thanks again!
      • Copier & Repair LLC
        Copier & Repair LLC
        • Aug 2017
        • 6
        hi there
        try to change the scanner circuit board.
        Copier Repair In Wisconsin Madison | Stoughton
        • D Colour
          • Oct 2008
          • 217
          Hi
          We are having this exact issue on the M2535DN, can you tell me what your solution was?
          Engineer has tried U021 and U002, but the issue persists.
          James
          Everything that has a beginning, has an end.....
          • oldtech1
            • Mar 2008
            • 35
            check scanner lock?
            • D Colour
              • Oct 2008
              • 217
              Originally posted by oldtech1
              check scanner lock?
              Yeah definitely off. The scanner moves freely.
              it must be a similar cause as Buzz, because the the drive assy was getting changed before the issue. Checked and reseated all the connections.
              • D Colour
                • Oct 2008
                • 217
                SB-COM-0314-E069.pdf
                DP Chart - DP.pdf
                Table Chart - File is too large, i'll upload a smaller file it tomorrow.
                • jessrhyl
                  • Sep 2019
                  • 5
                  Originally posted by D Colour
                  [ATTACH]37897[/ATTACH]
                  DP Chart - [ATTACH]37898[/ATTACH]
                  can you still upload the table chart?
                  • D Colour
                    • Oct 2008
                    • 217
                    Hi, still won't upload. Its only 6.5mb. Can you send me your email?
                    • jessrhyl
                      • Sep 2019
                      • 5
                      Hi
                      James
                      also experienced this in m2535dn
                      @year 2019
                      • jessrhyl
                        • Sep 2019
                        • 5
                        my email is jessrhyl@yahoo.com
                        thank you for responding.
                        do you have the originals for m2535?
                        302NM94340 & 302NM94330
                        • D Colour
                          • Oct 2008
                          • 217
                          Just sent you an email. Yes I still have the originals.
                          • jessrhyl
                            • Sep 2019
                            • 5
                            Great help sir.
                            Thank you for you time.
                            I'll check my email.
                            • DougMoney
                              • Feb 2017
                              • 70
                              Could I get a copy of the table chart too? My email is dougmoney@gmail.com. Thanks.
