Can someone tell me if the TA 2552c and 3552c toner compatibility I know they are different toners but can you tell me if the copystar and kyocera brand are interchangeable
kyocera TA 2552 color toner
Re: kyocera TA 2552 color toner
Same parts and firmware.Different toner.If it ain't broke, don't fix it
A picture is worth a thousand words -
Copystar and Kyocera toner on newer units are interchangeable. They started doing it a while back. I was told it was mainly done for national accounts so they could be serviced by a Kyocera or Copystar dealer. The last digit of the TK number designates when it is Kyocera or Copystar. Last digit of 7 means Kyocera and 9 is Copystar. When they are out of the Copystar toner they ship us the Kyocera toner. You used to have change the model destination for the toner 2 for Kyocera and 66 for Copystar or it would give an error due to the toner. But now the toner is the same now and works in both units.Comment
wkmiller
Re: kyocera color toner , TK-542 Toner usable for TK562 ?
Have a Kyocera FS-C5300DN, Can I use TK-542 Toner with it instead of the TK562 ?Comment
TASKalfa 2552ci uses TK-8347 or TK-8349, TASKalfa 3552/4052ci uses TK-8527 or TK-8529."If a cluttered desk is a sign of a cluttered mind, of what, then, is an empty desk a sign?" -EinsteinComment
TK-542 is for the FS-C5100DN printer. Then TK-562 should be used for the FS-C5300DN printer."If a cluttered desk is a sign of a cluttered mind, of what, then, is an empty desk a sign?" -EinsteinComment
