km5050
  • Franky Tan
    • May 2025
    km5050
    Error c6020 is it can be solve by using latest firmware ? can anyone tell me ? what is the latest firmware / thankyou ?
  • kyoceradude
    The Great Gazoo
    • Aug 2006
    • 442
    2.20 C is the latest.
    MAIN 2GR_2000.022.001
    MMI 2GR_7000.022.001
    ENGINE 2GR_1000.014.002
    SCANNER 2GR_1200.005.001
    My mission here on Earth is to help all you Dum-Dums!
    • Mark B
      • Jul 2006
      • 153
      Reset the code and replace the fuser connector. There is a bulletin on this
      • termacadon
        IT goofball
        • Oct 2008
        • 66
        2.20 C??
        KMEU has only released 2.20A where equitrac gets embedded etc.
        What new fixes are there? COuld you pm me the details and/or link to download?
        • kyoceradude
          The Great Gazoo
          • Aug 2006
          • 442
          Originally posted by termacadon
          2.20 C??
          EU may be different..... Heres the bulletin for it. Not sure how to attach a link for the firmware, because your in the EU and the file is too big to attach.
          • termacadon
            IT goofball
            • Oct 2008
            • 66
            FTP or URL? Firmware will work all round. If it doesn't... I will let you know that it was an expensive experiment!!!
            Do you know if this sorts out the problem with Equitrac, when you leave the machine over night and it goes into a deep sleep, then when you start it up in the morning, the panel just says "preparing" and it try's to communicate with the server, but the machine just hangs.
            • rafta_22
              hello,
              how can enter the setup of KM 5050?
              • Franky Tan
                Originally posted by rafta_22
                hello,
                how can enter the setup of km 5050?
                what u mean by setup ? Is it press status and then 1087 1087 ?
                • rafta_22
                  place where you can Reset error code etc..
                  • randula7
                    • 73
                    Press the status key then enter "10871087" using the numeric keys..........maintenance mode is entered
                    reset fuser error enter 163
                    you can print maintenance list using 000
                    enter 001 to exit maintenance mode
                    • rafta_22
                      thank you , it is ok now
