hlo very body. pleas I have task alfa 4500i give error code F1D6 ..if any one can help me to find firmwareal of it tanks for all
task alfa 4500i error code F1D6 need last firmware
Re: task alfa 4500i error code F1D6 need last firmware
seems like corrupted HDD, format or replace. Is the nearby cooling fan siezed? -
thank you .the fan is work good.I replace HD.but it it give the same error F1D6.Comment
from the manual:
F1DX
An error is detected at the
Image memory management
section
1) Format the HDD and check function. (U024 FULL formatting)
2) Execute the U021 Memory initializing to initialize the controller backup memory
and check function.
3) Replace the main board and check function.
4) Replace the HDD and check function.
5) Retrieve the USBLOG and contact the Service Administrative Division.
*The F1D4 error is RAM
allocation error.
๔1Check it with the U340
๔2Initialize the setting
valued with the U021
Maybe the Ram is faulty, easy to re-seat , clean edge connector, try some other laptop-size ram in itComment
