TASKalfa 2552ci main cover open waste bottle not installed
  • taskalfa
    • Jun 2011
    • 97
    [Misc] TASKalfa 2552ci main cover open waste bottle not installed
  • Scott
    • 196
    Re: TASKalfa 2552ci main cover open waste bottle not installed
    elementary question have you removed the WTB and reinserted it?? Kyocera has told us to not to install the WTB till it gets to its final destination to try to avoid this issue.. Hope it helps
    • craigster
      • Apr 2016
      • 201
      The WTB you ordered will fix your problem, be aware though that there is a new updated WT door also The old ones warp and pop open when on there own. I would get the door!
      • tommygun
        • May 2010
        • 21
        is the ground the tiniest bit uneven, was a problem for me, only the slightest lean caused me to have waste toner full
        • JR2ALTA
          • Feb 2010
          • 2033
          This may not be your problem but I had one that was calling to install the waste toner bottle and I couldn't satisfy the machine even with a new bottle
          As it turns out the black toner was empty and it was really prompting me to remove the black toner and install it as a waste bottle
          If you haven't been to class on this model you may not know that an empty black bottle is designed to be re-purposed as a waste bottle
          I don't know why the message was so misleading
          • taskalfa
            • Jun 2011
            • 97
            The only thing is that the copier is saying that the main cover is open followed by install waste box, so im assuming that the waste door switch isn't being activated, if only these copiers had some way of testing cover switches in maintenance mode, it doesn't matter which door or cover you open it indicates main cover open , very confusing. I'm hoping that the wtb arrives tomorrow so I can test
            • Tonerkiller
              • Oct 2012
              • 668
              When you get your wtb assy. make sure that you follow the disassembly directions. It will take about 2 hours.
              • Hose1cook
                Defective Technician
                • Jun 2008
                • 80
                You might want to take a look at this.QA_H159_2ND_0067_SB.pdf
                • taskalfa
                  • Jun 2011
                  • 97
                  Just a follow up, installed wtb and all is working, I think it was only that switch assym underneath the wtb that needed replacing as it wasn't recognising door closing , and if you've noticed that no matter which door or cover you open it always says "main unit cover open" what's with that
                  • sparkycivic
                    • Apr 2017
                    • 348
                    Some of these early copiers have sticky door switch cams at the sensor, so it sticks in the position that indicates door open. I have posted my workaround for that specific issue here before.
                    It gets replaced in the new wtb assembly.
