Taskalfa 5500i
  • symon_87
    • Mar 2013
    • 3
    [Misc] Taskalfa 5500i
    Hello everyone,
    I have a taskalfa 5500i and I need to make code u020 to do the general reset to the equipment. But the code you used to use 06141010 does not work on this machine. Anyone know if there is a new code? Thanks
  • laitang
    • Nov 2012
    • 627
    Re: Taskalfa 5500i
    U021 Memory initializing
    Description:
    Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history and mode setting. Also initializes backup RAM according to region specification selected in maintenance item U252 Setting the destination.
    Purpose:
    To return the machine settings to their factory default.
    Method:
    1. Press the start key.
    2. Select [Execute].
    3. Press the start key. All data other than that for adjustments due to variations between machines is initialized based on the destination setting.
    4. Turn the main power switch off and on. Allow more than 5 seconds between Off and On.
    * : An error code is displayed in case of an initialization error.
    When errors occurred, turn main power switch off then on, and execute initialization using maintenance item U021.
    Error codes:
    0001 Entity error
    0002 Controller error
    0020 Engine error
    0040 Scanner error
