Tier pricing on the Kyocera ECOSYS P5026cdw. ???
  • kuby
    • Oct 2007
    • 1400
    Is it possible to setup tier pricing on the Kyocera ECOSYS P5026cdw? Did not see anything in the manual like u332 on other models.
    Found the setting in the manual, they seem to be item 88 and 89 but how to go in to change the values of the from the default??
    Manual is not very clear on this.
  • kuby
    • Oct 2007
    • 1400
    Re: Tier pricing on the Kyocera ECOSYS P5026cdw. ???
    Figured it out - never mind
    • kuby
      • Oct 2007
      • 1400
      OK I know it's possible and even found out where to change the setting but I can not remember how to change the setting on the Kyocera ECOSYS P5026cdw?
      Found the setting in the manual, they seem to be item 88 and 89 but how to go in to change the values of them from the default??
      I remember now, you have to use the NET DIRECT PRINT command to change them.
