Taskalfa 5501i Fax Card
  • evest
    • Aug 2008
    • 58
    [Misc] Taskalfa 5501i Fax Card
    I am putting a Fax system W (b) card in a TA5501i, card plus flash memory stick. This machine has never had a fax option before. The fax card and flash memory stick are known functioning components. However I cannot get the fax to show up on the screen as well as the fax selection only beeps when pushed. Nor do I get the 0650 error code, which usually occurs. I usually go to service mode 671 and recover the fax, but that does not help. does anyone know what I should do.
    Oh I am already using it in opt 1 port.
  • evest
    • Aug 2008
    • 58
    Re: Taskalfa 5501i Fax Card
    I have the Fax W service and install manuals. But I Service mode 600 is not taskable. That is what they say to do so as to initialize the fax card port
    • evest
      • Aug 2008
      • 58
      Figured it out. U21 and it showed up. thanks anyway. don't all speak up at once next time. Yuk Yuk
