i need help with Kyocera FS-6525 FTP
  • 2010mohamed
    • Oct 2017
    • 28
    i have this message " Preparing to Print " on the screen left side up . and take very long time some time get ready to copy . and all the time never finish preparing .
  • Kyo fan
    • Dec 2013
    • 368
    Re: i need help with Kyocera FS-6525 FTP
    Print the status page and event log and post them here.
    • 2010mohamed
      • Oct 2017
      • 28
      thanks for replay . but i cant print any thing . the machine is preparing to print (the machine is working and i think developer is runing also ) i dont have any idea how can i print those paper for you
      any idea please i need help
      • 2010mohamed
        • Oct 2017
        • 28
        i need help please
        • JR2ALTA
          • Feb 2010
          • 2028
          Maybe you need toner
          • 2010mohamed
            • Oct 2017
            • 28
            i change the toner and drum and developer . and the same proplem
            any idea can help pls
            • tech28
              • Jun 2013
              • 434
              Have had a few Kyocera printers that were low in toner and I also replaced the developer, toner, oem, and they will just run, run, run and nothing. Just cycle, heck, I just left a couple of them running at the shop, overnight, came back the next day and they were ready to go? Running good. Weird machines when they run out of toner completely.
              • 2010mohamed
                • Oct 2017
                • 28
                i did the same you did and its ready . but after i turn the machine off and on . the same proplem any other idea
                • Rpizzle
                  • Mar 2014
                  • 47
                  if you unplug the network cable and cycle power does it do the same thing?
                  • JR2ALTA
                    • Feb 2010
                    • 2028
                    that's a good idea. "preparing to print" is the NIC initialization. Maybe he's got an IP conflict
                    • 2010mohamed
                      • Oct 2017
                      • 28
                      there is no network cable . any other idea
                      • Kyo fan
                        • Dec 2013
                        • 368
                        I would upgrade firmware next. If nothing changes, do U021 initialization. Keep in mind that will reset network settings, common settings, job accounting and will wipe the event log. That's not a bit deal since you can set it up again.
                          • 29462
                          you may have a fax trying to print on paper size that's not in machine. Fax setting has reduce to size paper is turn off , turn it on
                          or wait and see what the error is machine and insert that size paper.
                          Don't know of any way to delete a fax received in memory.
                          • 2010mohamed
                            • Oct 2017
                            • 28
                            sorry but i dont have fax also . so i dont know what to do
                              Originally posted by 2010mohamed
                              i need help please
                              you really haven't given us much to go on.
                              what type file are you trying to print?
                              what is the size of the file?
                              you say:
                              I cant ping machine ... have you tried looking at maybe an IP addy conflict?
                              what program are you using to print from.
                              not enuff info to go on.
                              if you can't ping that machine ... why change all those parts out?
