KM-1820 USB WIA scan
  • LNorris
    • Sep 2008
    • 645
    has anyone gotten this to work?
    KM-1820 hooked to a Vista PC, using WIA. i can get the scanner to show in the cameras and scanner folder, but when using a application to try to scan into it, it cant find the scanner.
    any ideas or someone that has made it work?????
  • n25an
    • Jul 2008
    • 1030
    Re: KM-1820 USB WIA scan
    Km-1820 hooked to a vista pc, using wia. I can get the scanner to show in the cameras and scanner folder, but when using a application to try to scan into it, it cant find the scanner.
    Any ideas or someone that has made it work?????
    uninstall the scanner and print drivers
    unplug the usb...
    Restart pc
    install the scanner and printer from cd
    install the wia scan from cd
    restart pc
    plug in usb for printer
    make sure that the printer is correctly auto installed from tray by the clock...
    If that doesn't work scanning wont work right...
    Once scanning works...
    Restart pc
    you are done...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
