Kyocera TASKalfa 406ci - code C7003
  • kuby
    • Oct 2007
    • 1407
    Have one of these that has a C7003 error code. It is about 6 months old, and have checked the spiral of the toner container, the couplings and gears rotate OK and don't seem to be broken. The connectors all seem to be secure. Going to have to order the toner motor. My question is there a way in service mode to make the individual toner motors spin or is there a way to cheat the switches so you can watch the gears and be sure there are turning with the front door open?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Kyocera TASKalfa 406ci - code C7003
    U135 Checking the toner motor operation.
    • kuby
      • Oct 2007
      • 1407
      Found out how to cheat the door switches. Tested the motors and the magenta motor never turns. Looks like a fun job replacing it.
      • kuby
        • Oct 2007
        • 1407
        There are three door switches you have to cheat.
