Kyocera 4035-light edges when scanned from feeder
  • soutec
    • 13
    I have a 4035 that makes excellent copies when you
    copy from the glass or print to it from the network.
    However when you scan from the doc-feed both sides
    of the doc (1 inch in) are are very light. have tried to
    adjust using sim 60 scan input and 74 doc-feed balance. Also replaced scan glass cleaned mirrors and replaced the exposure lamp. Any ideas what might be the cause. Thanks
  • LNorris
    • Sep 2008
    • 645
    does the "lightness" get worse as it scans? or is it pretty consistant down the edges of the page?
    • kyoceradude
      The Great Gazoo
      • Aug 2006
      • 442
      Adj sim 68. Adj dp scan position.
      My mission here on Earth is to help all you Dum-Dums!
      • soutec
        • 13
        Thanks all for the good information on the sim u068.
        I plan on going back tommorrow and give that a shot.
        Is it necessary to adjust sim's 65,66,67,70 and 71?
        Also do you have any idea what would cause the adjust
        ment in sim 068 to change? Thanks for all the great help!
