Kyocera TA3510i Printing Issues
  • lightningazure
    • Jan 2018
    • 8
    [Misc] Kyocera TA3510i Printing Issues
    Guys need I do need help. Machine Model Kyocera TA3510I.
    The issue is i get dark background even when copying single print blank white paper(Attach "single"). The background was even worse when duplex (attach "duplex 1 & duplex 2". I have already cleaned Drum, Transfer roller, Main Charger, but the problem is still the same. single.pdfduplex 1.pdfduplex 2.pdf
    • 30227
    Re: Kyocera TA3510i Printing Issues
    OEM Toner? in machine
    • lightningazure
      • Jan 2018
      • 8
      Use 3500i OEM Toner to refill
      • Kyo fan
        • Dec 2013
        • 368
        Replace the developer unit (DV-7105).
        • lightningazure
          • Jan 2018
          • 8
          Is there a way to test if the developer unit is faulty, as I don't have a spare one around and it will be a waste of money if I get a new one and still won't fix the problem
            • 30227
            Dev unit should have a 3 year warranty if your a dealer or maintenance kit has been installed under the Kyocera warranty
            Only way to test is to install in another machine.
            • itchyfinger@att.net
              • Oct 2017
              • 77
              agree looks like developer unit to me
              • sparkycivic
                • Apr 2017
                • 348
                Perhaps, try to clean any and all build-up and debris from the developer mag roller and other surfaces of the developer, to prevent charge from draining.
