Kyocera Taskalfa 4052 error" Toner Seat empty main cover open"
  • bryant28282000
    • Jul 2012
    • 145
    Has anyone seen this problem, We are using OEM cyan toner and the machine is reconizing the toner as being empty. We have tried 3 toners
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: Kyocera Taskalfa 4052 error" Toner Seat empty main cover open"
    Yes I have. I realized it was prompting me to put the empty black in the waste toner door. If you're not aware, empty black toners are repurposed as waste bottles. I don't know why the machine was insisting I do this or why is was worded so poorly but it worked when I did it.
    **edit**
    sorry I didn't see about CYAN. but ill keep my post up in case it helps someone else
    • taskalfa
      • Jun 2011
      • 97
      Just a suggestion, maybe the main cover open is the issue and not the toner, we have had the waste toner door sensor fail causing it to show waste toner bottle error and check main cover.
      • Tonerkiller
        • Oct 2012
        • 668
        Yeah, I have seen the door not closed properly also, the machine will not add the toner until the door is closed
        • pascalb.
          • Aug 2016
          • 47
          Hello,
          I had two times.
          The toner delivery pipe block.
          PWB Feed image HS.
          Do not lament,
          do not mock,
          do not hate,
          but understand.
