kyocera FS-6525MFP cassette1 failure . new proplem
  • 2010mohamed
    • Oct 2017
    • 28
    when i open cassette 1 its stuck hard to bull out after a while i take it out and i saw this
    and i fix back and when i insert tray 1 again i heard sound so lowed and back again like in the photo
    the normal way like this
    i need help please
  • taskalfa
    • Jun 2011
    • 97
    Re: kyocera FS-6525MFP cassette1 failure . new proplem
    I have had instance were the tray would keep lifting due to the pick up assym not detecting when tray hits the sensor. If the copier has 2 trays try swapping the pick up assym and see if it makes a difference. If it locks up in an error state then you need to go to system menus and reset code, from memory these copiers don't have the u906
    • 2010mohamed
      • Oct 2017
      • 28
      thanks you for replay
      but still the same
      • 2010mohamed
        • Oct 2017
        • 28
        but still the same problem
        i need help please
        • Andrew Alphonsus
          • Sep 2015
          • 9
          Dear Mohammed
          Press Service menu button and press drop down button on the Touch panel..Select Service settings . Input login no.2500 and password 2500 using numeric keys.
          then select reset cassette failure and click enter key. Then switch OFF the machine and then ON.
          Then cassette error code issue will be resolved.
          Good luck
          Bye
          Andrew Alphonsus
          • Haddat
            • Apr 2011
            • 13
            I have the same problem with me. the suggestions here did not work. Any other suggestions? :O
            • Haddat
              • Apr 2011
              • 13
              I found ..
              I found
              • 2010mohamed
                • Oct 2017
                • 28
                Originally posted by Andrew Alphonsus
                Dear Mohammed
                Good luck
                Bye
                Andrew Alphonsus
                thank you so much
                • Drewsup
                  • May 2019
                  • 9
                  had a lot of problems with these either overlifting the paper, or incorrectly saying how much paper left, most have been sorted by replacing the paper sensor flag (white) and the pcb with the sensor on it
                  Wish they just go back to spring loaded cassettes on these small machines, its too complicated for what it does
