Kyocera M3550idn
  • Thayer
    • Dec 2017
    • 108
    [Jamming] Kyocera M3550idn
    Brand new machine, 500 copies
    Keep getting J9200 and 9210 adf
    Weird thing I get 9200 when scanning to email and 9210 when making copies.
    Blew out sensors and checked actuators, 2nd call about this issue. Any thoughts??
    Boss wanted me on to next call so not alot of time to trouble shoot!
  • itchyfinger@att.net
    • Oct 2017
    • 77
    Re: Kyocera M3550idn
    9200
    DP registration sensor
    non arrival jam
    DP registration sensor (DPRS) does not turn on within
    specified time of DP feed sensor (DPFS) turning on.
    H
    9210
    stay jam
    DP registration sensor (DPRS) does not turn off within
    specified time of DP timing sensor (DPTS) turning on.
    see if the acturator is hanging up. see if switch changes states with a meter reseat your connectors at switch and adf main board
    • Tonerkiller
      • Oct 2012
      • 668
      I have seen this with these little machines. Take the adf off and you will see that one or both hinges are broke. You cannot really tell until you take the feeder off.
      • Thayer
        • Dec 2017
        • 108
        Follow up call today
        Found actuator sticking, cleaned, lubed and added extra tension on the spring.
        Ran 100 documents, time will tell if it fixed it!
