P6035CDN
  • Hilltoner
    • Jul 2025
    [Misc] P6035CDN
    Hi I have seen the information about how to get to the drums on Kyocera P6035CDN printer but it says just to pull drums out they do not move as there must be some other lever or device that keeps in place as I need to replace only one drum can someone point to what else needs to be done to remove the drums.
    Regards Kym
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: P6035CDN
    Regards Kym
    The drums just pull straight up. Looks at picture. At the top, each end has black contours that you can grip and pull on.
    • vee1989
      • Nov 2017
      • 34
      Re: P6035CDN
      Not sure if this machine is similar to a P6130, there should be a locking lever on the left side of the machine which has to be pulled up to unlock the drums.
