NEW!!! TA 9002i
  • craigster
    • Apr 2016
    • 201
    [Misc] NEW!!! TA 9002i
    Got to laugh how Kyocera announces a new machine but its not on the kyocera dealer site yet!!
  • Tonerkiller
    • Oct 2012
    • 668
    Re: NEW!!! TA 9002i
    Its there. It is just an 7002 that is 90 ppm. The manual is a 7002/8002/9002. Webinar is tomorrow.
    • Geo
      • 662
      Re: NEW!!! TA 9002i
      What I understand from TB1 ,300K MK is eliminated and the 600K MK finally has tires included and tires are rated for 300K. So the Fuser and tires must be beefed up.
      • toddanderson
        • Dec 2005
        • 236
        Re: NEW!!! TA 9002i
        I would say nothing was beefed up,
        All the tires added together is 300k not each tire 300k
        little change in the fuser it wont last 300k let alone 600k
        these yields are just marketing numbers and trying to market a low cost per copy
        • Geo
          • 662
          Re: NEW!!! TA 9002i
          So why did they eliminate the 300k MK ? We know the fuser has trouble reaching 300K , so I Doubt hey did not beef it up. As for the tires,TB states that they are 300 k tires , and even if we use your math ,the yield would be 600K.
          • itchyfinger@att.net
            • Oct 2017
            • 77
            Re: NEW!!! TA 9002i
            going to school in Chicago later this month on the series. any problems out there ya all have seen?
              Re: NEW!!! TA 9002i
              you mean besides the local government and crime in the streets right?
              • toddanderson
                • Dec 2005
                • 236
                Re: NEW!!! TA 9002i
                The feed tires are a common number used in others, its not just simple math on the feed tires as most copies are ran from the default cassette, all the tires are replaced at pm for the 300k
                no one tire will ever get 300k
                The fuser is only one number change 50 to 51 , it basically the same fuser
                they move everything to 600k to get a lower cost per copy
