P6035 service mode
  • selig67
    • May 2008
    • 158
    P6035 service mode
    I can print out the service status page, but how do I adjust the settings? Doesnt seem to have a way to access it. Unless you have to start up in service mode?
    thanks
  • Santander
    • May 2009
    • 768
    Re: P6035 service mode
    thanks
    What setting(s) are you trying to change? The service mode is not like a copier. If you are trying to change a setting to correct a problem what is the problem? A little more info would be helpful
    • selig67
      • May 2008
      • 158
      I am trying to see if this Kyo can be set up with two tier color meters like the bigger boxes. line 77 of the service status page shows what could possibly be the way to change it. Is this service status page just showing what the machine is set for from the factory, or can it be changed?
      • GeneOR95
        • Feb 2018
        • 161
        General Technical Bulletin #97 Explains how to set this using a PRESCRIBE Command. The relevant section is three pages.Pages from General Bulletin 97.pdf
