Kyocera FS-C8520 toner pump installation
  • jonbonse
    • Jun 2009
    • 737
    Morning all
    I recently attended a FS_C8520 which kept requesting black toner. I found that the toner shutter door plate which sits under the black toner cartridge was broken away which resulted in the toner not dropping down to the pump. So I removed the shutter door from the toner and removed the shutter door plate from the machine but it still requests black toner. Genuine toner in use.
    There is also a clinking type noise when it tries to add toner and when running.
    I assume the pump is making the clinking noise and wanted to see if this was an easy replaceable part?
    I have experience on replacing the toner pumps on Ricoh MPC2800 series and know that is straight forward - 20 mins job there abouts.
    I also wondered if it has caused damage to the gears that turn the toner and dev?
  • Tonerkiller
    • Oct 2012
    • 668
    Re: Kyocera FS-C8520 toner pump installation
    I think you have the wrong toner, or a bad toner cartridge. I am thinking that the clicking noise is coming from the toner cartridge motor trying to drive the augers in the toner cartridge.
    • jonbonse
      • Jun 2009
      • 737
      Thanks for the input
      I checked the toner gears and tried new cartridges.
