Printing with Linux on a Taskalfa 4052ci
  • taskalfa
    • Jun 2011
    • 97
    [Misc] Printing with Linux on a Taskalfa 4052ci
    Hi, can anyone help with a printing issue, when customer prints from Linux to a 4052ci it prints from tray 1 and if paper runs out it doesn't continue to next available tray , the copier has 4x 500 sheet trays. Is there a way to set it to print to auto tray source?
  • shamgar1981
    • May 2012
    • 34
    Re: Printing with Linux on a Taskalfa 4052ci
    • craigster
      • Apr 2016
      • 201
      What Driver are you using? If you are using a generic driver for linux
      it will most likely use tray 1 as default because it does not recognize the options on that model. Just a thought!
      • taskalfa
        • Jun 2011
        • 97
        Driver is current 8.1605
        you would think there would be an auto source settings in Linux , at the moment it is (InputSlot/Media Source: *Default Tray1 Tray2 Tray3 Tray4 Manual Envelope
        im assuming the * indicates its set to Default, and the copier is set to tray1 as default. So I might have to group trays 1&2 as suggested
