SLOW PDF PRINTING ON M2552ci
  • vsluggo
    • 23
    [Misc] SLOW PDF PRINTING ON M2552ci
    We have a construction company that is trying to print PDF 2 x 3 blueprints at 50 % of the size or on 12" x 18" sized paper, so its to scale and they are complaining that it takes 1/2 hour to print a 16 MB file......
    Yes we are using the KX drivers , yes it is defaulted to B& W/grayscale we are printing as an image,
    Everything else prints alright. They say that the Konica Minolta C252 they had printed faster than this....
    Their IT guy is putting it off on us...he says he's done "all the right things" (but we've all heard that before)
    ANY SOLUTIONS?
  • shamgar1981
    • May 2012
    • 34
    • Kyo fan
      • Dec 2013
      • 368
      Re: SLOW PDF PRINTING ON M2552ci
      Upgrade firmware to the latest and use different pdf reader. I usually recommend Foxit pdf reader.
      • toddanderson
        • Dec 2005
        • 236
        Make the originals 12x18 in the first place , it you are letting the print driver convert to 50% that is why
        its printing slow.
        take the pdf to a different machine same models and test them.
        ANY SOLUTIONS?
        • mincopier
          • Dec 2015
          • 289
          Open the spooler on the computer and see what the file is ballooning up to. I have a customer with a Ricoh wide format that their 16MB balloons to 1.08GB using a PS driver.
          With the KX driver you can also set it to use PCL.
          • vsluggo
            • 23
            [QUOTE=shamgar1981;601437]
            • Up to date Tech
              • Jan 2018
              • 31
              I had the same issue with the same model I updated firmware and reinstalled drivers worked for me
              • darry1322
                • Oct 2010
                • 817
                I had a 3252Ci printing pdf files slow and it turned out to be a bad network drop.
                • tomasz.kolakowski1
                  ANY SOLUTIONS?
                  Driver issue.
                  Sent from my HTC Desire 10 pro using Tapatalk
                  • MIGUELMARCHENA
                    • Feb 2018
                    • 195
                    I've had several calls from customers for the same, astonishing slowness in printing pdf
                    as a curious note
                    everyone has adobe reader for free
                    • guitar9199
                      • Sep 2016
                      • 1100
                      Go into the "Advanced" settings in the Adobe print protocol, and put a check in the "Print as Image" box. If you're using postscript, most of the time the drivers process each "Layer" of the PDF separately, causing it to take forever to print. Flatten it out to one layer with the Print as Image box, and that should speed things way up.
                      +1 on the resizing of the document BEFORE printing it.
                      • printlessguy
                        • Sep 2015
                        • 63
                        I work with Vito and here is some more info.
                        upgraded firmware to newest from Kyocera.
                        plug usb into printer with same file. is a 16mb pdf. choose 12x18 paper in 2 minutes 15 pages print out then I canceled job. it is a 40 page doc.
                        have user use adobe with b&w settings sends 5 pages with setting print as image. 5 pages take 9 minutes.
                        have user send same 5 pages normal settings 2 pages in 9 minutes.
                        they are direct ip printing.
                        the doc balloons to 180mb when sending full job. it spools to the printer pretty fast. maybe a minute ( gigabit network). but it then just hangs out at the printer processing so slow.
                        on a side note in our office (100mb network) we have a 3050ci and when we send the same file to it (only using 11x17) it spools and prints out 1 page maybe 5-10 second wait then next page
                        almost same speed as the 2552 printing from usb stick
                        any more thoughts?
                        thanks
                        andy
                        • darry1322
                          • Oct 2010
                          • 817
                          I would try printing to the machine with a laptop or PC plugged directly into the network port to eliminate any network issues or bad cabling.
                          • GeneOR95
                            • Feb 2018
                            • 161
                            There are several PDF programs that I use for testing. (PDFXchange viewer, BullZip, Nitro Reader). For the most part these do not have the overhead of Adobe products. If the file prints OK with one of these I know the problem is with Adobe. If not the problem is most likely the file.
                              • 30216
                              KX driver what is emulsion set to? should be set to pcl5
                              also try a mini driver
