FS 6525 olivetti 253)
  • Gab
    • Aug 2015
    • 677
    A capacitor blew up at power supply , I fixed power sypply and an erro 6030 appeared .
    This error is about thermistor . Can it be something else connected to power supply.
    Re: FS 6525 olivetti 253)
    DAMN RTFM! you post quite a few questions .... but it seems you NEVER look in the manual. When the rest of post problems here, we have already been thru the manual and it doesn't have a clear fix or the fix doesn't solve the issue and all possibilities have been exhausted.
    the thermistor is in the fuser.
    • patrickjlc
      • Feb 2015
      • 225
      Once you replace thermistor remember to reset error code, u163 if I am not mistaken
      Sent from my SM-G930V using Tapatalk
        hell if he broke out the manual he could have answered his own question... but no.. don't research... just pick others brains ... smmfh
        that's why he has 100+ posts and ZERO rep power!
        • Gab
          • Aug 2015
          • 677
          If you read my post i refer that manual says it's thermistor. I just ask if it can be something else.
          • avio2
            • Jul 2010
            • 150
            but the fuser heater turn on?
            • patrickjlc
              • Feb 2015
              • 225
              With a c6030 will only turn on for a second before the bad thermistor is detected and give the code again. Replace the thermistor, or fuser unit if you have one, run sym u163 and done.
              • avio2
                • Jul 2010
                • 150
                Well but GAB repair pwb in Advance
                Sure that correct tensione at Heather Fuser?
                  "This error is about thermistor . Can it be something else connected to power supply."
                  there is your post...doesn't say a DAMN thing about the MANUAL just " "This error is about thermistor " you could look up that information on GOOGLE.
                  • avio2
                    • Jul 2010
                    • 150
