FS 9530 grey background
  • Llurch
    • May 2016
    • 5
    Hi All,
    I have just installed a maintenance kit in a Kyocera FS-9530 and now the pages print
    with a grey background. The firmware is fairly old. Has anyone had this problem with
    this model?
  • Kyo fan
    • Dec 2013
    • 368
    Re: FS 9530 grey background
    What kind of toner you used to fill up developer unit after replacing MK?
    • Llurch
      • May 2016
      • 5
      The original Kyocera toner that was already in the printer.
      • vee1989
        • Nov 2017
        • 34
        Usually this happens with generic toner. You need to clean out the developer which should resolve your issue.
        • Llurch
          • May 2016
          • 5
          The developer unit is new with the maintenance kit.
          • vee1989
            • Nov 2017
            • 34
            Did you try wiping the developer roller clean ?
            • Llurch
              • May 2016
              • 5
              The developer unit is new. I put the old dev. unit back in and the problem was still there.
              Also put the old charge corona back in with no improvement. I'm wondering if it could be due to
              old firmware. I'm thinking maybe the drum specs have changed with later drum units and a firmware
              upgrade is needed to match it.
              • vee1989
                • Nov 2017
                • 34
                Make sure that all connectors are clean from dust/toner. Maybe also do alot of prints and see if the grey background gets lighter. I have this exact machine with over 2 million prints and only experienced this issue when generic toner was used/mixed which caused a grey background.
                • Llurch
                  • May 2016
                  • 5
                  Problem solved.
                  Found a trimpot on the top rear of the drum unit. Gave it a tweek and no more background.
                  Thanks everyone for your help.
