FS 6525
  • Gab
    • Aug 2015
    • 609
    FS 6525
    Error 6030. I turned off /on machine and now error 6000.
    I checked fusing and fusing lamp was the problem
    Replaced fusing unit and now when i turned on machine panel is white (it lights but nothing appears on screen). Iput on again the previous fusinng the same. I connected ethrnet and it lihgt ok also i connected usb cable and at the computer "new device...."
    Pressed 10871087 with no result
    Any idea?
  • sparkycivic
    • Apr 2017
    • 348
    Re: FS 6525
    is the 5v supply working? it Could have been waiting for a chance to die
    • Santander
      • May 2009
      • 768
      Re: FS 6525
      Any idea?
      Since you have replaced the fusing unit that the two codes you state point to and as you describe that connecting the unit via usb to a computer and it recognizes the 6525, this tells me that the unit is mostly operational. I would start with putting the new fuser back in the machine and then reloading the firmware from a non-turbo pack usb. Since you say that you entered 1087/1087 in the copy mode and it did not allow entry to the maintenance mode, the firmware may be corrupted. Hope this helps.
