4002i warning low memory
  • nathicana
    • Aug 2008
    • 332
    I was setting up this brand new 4002i and noticed a blinking memory light that would not go out. After continuing to run copies for a while the message came up "Warning low memory cannot start the job try again later."
    Turning the machine off and on made it work again but I'm concerned the problem may come back.
    So far I have updated the firmware to 4.0
    Has anyone experienced this?
    Re: 4002i warning low memory
    your memory is getting filled... find out what jobs are being stored and delete them.
      • 30159
      Run a hhd format
      • ntbann
        • Jan 2012
        • 628
        We just had one with the flashing memory light. It turned out to be an old TA3050 driver being directed to the new printer. Changed to correct driver and all is good.
        • nathicana
          • Aug 2008
          • 332
          I kept the machine in the shop for a few days and the problem went away. There were no jobs in progress while the problem was happening.
          Prior to having the problem the machine took a really long time to register the remote services settings. Maybe that had something to do with it.
