ECOYSYS 6525 Fax
  • Raymann
    • Apr 2015
    • 73
    ECOYSYS 6525 Fax
    Finally plugged in the fax card on this machine. When I use it it hanges on to the pages one at a time. wont go into memory When we send something sends one page then next page..........
    Any Ideas thanks Ray
  • copiertec
    • Jan 2016
    • 2174
    Re: ECOYSYS 6525 Fax
    Assuming you have followed Kyocera's recommendations if it is a VIOP, have you tried going into U660 and changing PSTN to PBX?
      • 27779
      go to fax setting rx turn fax bulk
      will receive to entire job and print them out
      • Raymann
        • Apr 2015
        • 73
        not sure what a viop is or what the recommendations are. I have been in contact with tec support from Kyosera and have slowed down tx speed to no avail. I can try the pbx switch I will try anything at this point........Thanks
        • Raymann
          • Apr 2015
          • 73
          I am willing to try this even though I am having issues with tx not receiving...Thanks
          • copiertec
            • Jan 2016
            • 2174
            Oops, my dyslexia kicking in, VOIP (Voice Over Internet Protocol)
              • 27779
              Sound odd check adf is set for sound like single mode should be multi pages also check default settings. You can do a reset on fax is 600 something should everthing back to factory settings.
              • Raymann
                • Apr 2015
                • 73
                Well today I went out and in the user menu. I checked the bulk fax mode and it was on. However a I turned off the tti in the user menu and it reads the fax job at once. Not sure what the hell tti is but that fixed the issue....................??????????
                • Santander
                  • May 2009
                  • 768
                  TTI is just shorthand for Transmit Terminal Identifier, that is the information that is at the top of every page the unit sends. It is required in most countries. Actually turning off the bulk fax mode is what solved your situation as it collects fax transmissions to send in bulk as opposed to individual jobs.
                  • CleanTheSlitGlass
                    • May 2018
                    • 19
                    • Raymann
                      • Apr 2015
                      • 73
                      interesting...but I did not turn off the bulk fax mode just the tti..........I shall investigate soon......
