FS-9530DN - Call Service F030:0300100?
  • Bdok
    • Jun 2025
    What does this error code mean on a Kyocera FS-9530DN?:
    Call Service
    F030:0300100
    It's been showing up intermittently on the printer. Powering off seems to clear it for a awhile.
    Thanks!
  • blsquires
    • Nov 2008
    • 342
    Call Service
    F030:0300100
    Thanks!
    Main PWB system error
    Defective main
    PWB.
    Replace the main PWB and check for correct
    operation.
    although this is the fix by the manual they usually only need a firmware update
    • 10871087
      • Jan 2005
      • 1143
      Agreed, you might want to add in a re-seat of connectors and boards for good measure.
      • Bdok
        Thank you -- that's very helpfull!
        • LNorris
          • Sep 2008
          • 645
          double-check the print driver make sure its the right version with the pc/server being used. we had this show up on a color Kyocera printer. swapped boards, firmware and such, still didnt work right. put it in my office and it works fine. this was a c5015...we put a 5020 in its place and it works fine now.
          • madas
            • Aug 2008
            • 313
            F030 error
            this code is also associated with corrupt files sent to the printer. i have never had to change the board or dimm. turn off the m/c unplug from the network turn on the m/c it should reset. check print queue and delete the offending file recconnect to the network should be fine
            • KyoSpec
              Call Service
              F030:0300100
              Thanks!
              It is extreemly unlikely the error is caused by a hardware fault, simply updating the driver often resolves the problem, worst case updating the firmware should resolve the fault
