problem in kyocera km1635
  • zakichanedz
    • Aug 2025
    hi, i buy a new copier kyocera km1635 but i have a problem, the paper in out is half written.
    what 's the problem
    • i use the toner of evaluation
  • leroyal
    Expert on The Obsolete
    • Sep 2007
    • 156
    Make sure that the machine and it's paper cassettes are set for the size of paper you are using.
    I know what I know better than anyone else knows what I know.
    • zakichanedz
      hi, thank you for the answer, the problem was solved, i let it 24 h then it work very good
      • guymortier
        KM-1635 solution
        In witch direction?
        • zakichanedz
          what's direction?????
