kyocera fs6525mfp - light copy
  • Warstg_20
    • Sep 2009
    • 72
    hello....
    ..,fs6525mfp having a copy quality problem, its copyin ang printing light copy...
    ..,any suggestion are very much appriciated.
    thanks & more power
    warlits
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: kyocera fs6525mfp - light copy
    If it's in a dirty environment you could have a dirty polygon mirror inside the laser unit. Not hard to access, underneath the exit cavity.
    Again, it's not the laser glass that causes it, it's the 5 sided mirror. Typically a cloudy smudge on each edge of mirror face.
    • Warstg_20
      • Sep 2009
      • 72
      thanks for quick responce...
      we already clean the glass and even the polygon mirror,
      as of yesterday we isolated drum kit, its function well on the other machine..
      thanks
      warlits
      • JR2ALTA
        • Feb 2010
        • 2033
        thanks
        warlits
        In the future, please post what you've tried first.
        • Luther
          • May 2006
          • 682
          Sounds like this machine is in eco print , hit the function button on the bottom left of the copy screen, go to page 2 and see if eco print is turned on
          • jewen25
            • Mar 2009
            • 197
            thanks
            warlits
            Try to chk developer unit
            ERROR HELP ME AND HELP YOU
              hello....
              Thanks & more power
              warlits
              what have you done to it?
              what is total page count?
              counts on consumables?
              did you clean the laser lens?
              you REALLY need to provide more info IF you expect help with your problem!
