crooked copies
  • luis8832
    • Dec 2008
    • 250
    [Misc] crooked copies
    I am working on a M3550idn. Copies come out fine from paper cassettes. When using the bypass there is a slight slant. Any ideas or has anyone else experienced this. Thank you all in advance.
  • patrickjlc
    • Feb 2015
    • 223
    Re: crooked copies
    Try cleaning the bypass tires and guides
    Sent from my SM-G930V using Tapatalk
    • George J
      • 107
      Re: crooked copies
      I once had a broken cover ie the black bit that holds the mp tray and where the paper passes over into the registration area. I recall seeing the piece in the part list, but it had no asociated part number.
      Haven't really checked since.
      Also check for obvious things like pieces of paper stuck somewhere between the mp tray and the registration or the side guides that open during printing.
      • Geo
        • 662
        Re: crooked copies
        Check out this thread... TA-8002 belt run off
        The picture with the feed assembly is most likely your problem..Assuming that cass guides are tight and parallel.
